No water Flo...
Yooper91
I have a 94 Mariner Magnum 40HP, serial 0G138021 with water flo issue
I replaced impeller with a complete kit, but still no flow out of motor.
At a loss of whats next to try... Any help is appreciated
hardwater fisherman
How are you testing your water pump?
GA_Boater
Only by putting motor back together.
How else would you test it?
You can't test a water pump without water. And not on muffs. Use a large and deep barrel or back the boat down a ramp until the lower unit is deep under water.
Yooper91
I used muffs with the garden hose ..
Has always worked before when I run before each season
Not the correct way to test a new pump?
I did notice some water coming out of the exhaust by propeller
Sea Rider
How old is the motor, was run in fresh or salt water ? Remove the thermo and check the internal housing condition, is it clean, rusted, salty ?
Happy Boating
mike_i
Did you have a water pump issue before you changed the pump?
hotrod53
I've had times where my motor wouldn't pump on muffs but would if submerged.
Before you panic, get yourself a piece of string trimmer string. Push it up in your pee hole and be sure mud dawbers haven't clogged your pee hole. Happens all the time.
