Twistedcherokee
- Aug 19, 2023
- 15
I have a 1991 Rinker Captiva Cuddy 206 with a 5.7 Mag. Had forward and reverse before I pulled the lower unit off to install a water pump complete with upper pocket. I have tried the bungee cord on the prop, turning the shift rod clockwise until it locks in the prop ccw. Put grease on the upper shift rod and made sure it was in the forward position. Still no reverse. I can get reverse no problem with it off. Need help. I pulled it off and put it back on 3 times and the last time it was trying to lock in reverse so I tried to adjust the cable and now it’s back to no reverse. Anyone in the Ogden Ut area that can help? Toby
