- Oct 25, 2011
- 24,893
Re: Newby on 1st restoration 77 Galaxie Mark IV
These guys WONT let you down. Great info & resources in each of their signature threads! Frisco may swing through and give you a hand too. Check the last 50+/- posts on Jasoutside's thread, solo lifted his motor in & out w/ overhead chain hoist, if your garage rafters or garage door header will take the weight, it might be a possiblitity. Please ignore the nonsense, we ( I ) misbehave & mess around in his thread while he's not around
. Hopefully you can get your stern lower then Jas did, he pretty much had to lift the motor over his head to get it to clear the transom.....
Except the ply under your bricks, I don't have much other then:
Welcome to dry dock, hope the Admiral & the 1st Mate are looking forward to a project & enjoying it when you get done!
read this.....all you need to know....its a long read....but every thing is there in detailhttp://forums.iboats.com/showthread.php?t=234392 frisco has vids....http://forums.iboats.com/showthread.php?t=510077
With that much rot, you should do a really good inspection of your transom. I highly suspect it will be bad in need of replacement as well and you will HAVE to remove the motor ...
