newbie with painting questions!!!
mo boater
ok, i have an 89 chapparal cruiser that is lacking on the looks side. i have sanded, buffed, and polished til i'm sick of it!! i'm ready to paint!!
here's the deal...i own/run a body shop so access to automotive paint is the easy part...my questions are will the auto. clear coat hold up underwater as the boat will be spending its time in a slip? also will the algae also build up on the clear coat as it does the gel coat?
thanks guys!
alan
Davinciman
Re: newbie with painting questions!!!
thanks guys!
alan
It doesn't matter what kind of paint you put on, if it will spend anytime in a slip it will need "anti-fouling" paint on the underside of your hull and your outdrive.
People don't usually clear their outboard or outdrive. below the water-line.
What paint are you using?
mo boater
honestly wasnt planning on using any "paint", just sanding the gel coat down and clearcoating over that.
what type of "anti-fouling" paint do you reccomend? and will it be sprayable with a hvlp gun? i do not want to use any type of brush or roll on. (just personal preference).
thanks
