Re: New Project, First "adventure" into boating
Unfortunately, no one but you can answer the 'worth it' question. All used boats that have ANY wood or flotation foam in them should be considered suspect until PROVEN that there is no water anywhere it shouldn't be, and never has been. Aluminum boats also suffer from waterlogging, in them it's usually the flotation foam that's 10-20times original weight, and the odd bits of wood used to build out the interiors.
So, the real question is, how much time can you spend putting it back together, and how much money. Get a different boat & you may face the same, or worse conditions. Finish putting 1 back together & you KNOW there is nothing else that could have been anywhere any better on YOUR boat. The satisfaction of finishing it will be HUGE, but a fair amount of work.
I weighed the work to be done on my FireFlite, and although it will get finished, it is a time commitment that I wasn't willing to wait on. So I got an aluminum Jet. And it has also required more work then I'd hoped, but it will see water again much sooner then the FireFlite would have. Looking for parts & pcs for both boats & motors leads to more boats, motors & trailers in & around the garage.
It looks & feels worse then it is. It can always be fixed. All the glassers before you have been at this precipice, it isn't fun, nor is it easy to explain to someone who asks "Why & is it worth it?"
