new motor advice
Haut Medoc
Re: new motor advice
I strongly urge you to follow Don S's advice.....
You won't be sorry.......;)
Don S
Good, now you get things sorted out. I'll get you some merc links so you can see they change the ECM,
As far as that
button goes. It's seldom needed and causes more problems than necessary.
kellydee
Thanks a lot guys.Thanks for the welcome and for your time.This is really a different thing for me(comunication via internet)I do hardwood floors for a living and typeing or e-mail is not usually not my thing.I do better with a phone.(or so I thought).This is a cool thing,being able to talk about things and learn without having to go to the store and learn from the sales staff.There is a LOT to be said for experiance.
Don S
http://www.mercurypartsexpress.com/PartsExpress/HomePage/homepage.asp
>Click on accessories
> Type in zipcode
> Pick a dealer, it doesn't matter which, you are just looking.
> Engine Accessories
> Mercruiser
> Closed Cooling Kits
Now you have a choice, Dry joint or MCM Pre Dry Joint.
That is the type exhaust system they have. If you buy an OEM engine from a Merc dealer, it will have Dry Joint exhaust. That is a GOOD thing. But the engine driven raw water pumps are necessary on the Merc Closed cooling system because the manifolds are FW cooled also.
Not a big deal, but the raw water pumps are a PITA to change, along with the cool fuel system............
Any-Way,,,,,,,, look around. It's the OEM site.
kellydee
Thanks Don.Idid see the ECM change but,in their note (4) it says they will credit you back for the original ECM when you return it along with the ECM credit voucher located in the box with THEIR cooling system kit.So as you said befor,order it that way,it's already done.You obviously know your stuff.Thanks again for your time .
HT32BSX115
Hold on there!!!!
There's people who know where Buckley is and are not afraid to show it!! :%
Now that you have revealed you're in Buckley......WHERE IN BUCKLEY? (I'd love to see your installation! we could compare notes!!) I'd also like to talk about wood floor "stuff"!! )
By the way, If I could have found an MPI FWC big block/Bravo I would have jumped on it!!
8)
Cheers,
Rick
kellydee said:
Haut said:
I'd have to say that your engine was not running very well to have that sort of fuel consumption.....
What section of Seattle?......:)
Actually Buckley,I always put seattle bacause almost NOONE knows Buckley,WA
kellydee
HT32BSX115 said:
Hold on there!!!!
8)
Cheers,
Rick
Hey Rick,My name is Jerry(kellydee is my wifes screen name ,guess I should get my own)What a small world.Never thought I'd actually run into someone else from BUCKLEY here.If you send me your email add,I'll send you my phone # and we can "compare notes" or talk floors or both.I'm right near S. Prairie. kellydee@centurytel.net. 8)
