etransfer
- Jul 29, 2007
- 63
A few weeks ago I bought a new 2008 Tahoe Q6 SF and here's my review.
The boat came clean and waxed etc. but I had to tighten almost all the bolts and screws etc.. It seemed like everything was loose for some reason but once I fixed these they are now tight.
The boat came with a 4.3 V6 MPI 220 HP motor and is 21' long.
First the bad:
The boat was fast out of the hole but would go down in the water several feet causing the bow to rise high I was blind for 5 seconds or so.
The boat rocked really bad side to side when I hit another boats wake.
With three adults I got up to 57 MPH at 5200 RPMs at max throttle.
With the stock alum prop at 4100 RPM's it went 35 MPH and at 4700 RPM's it went 45 MPH. At WOT 5200 RPM's it went 57 MPH. The engine alarm sounded so I backed off at this RPM !
The good:
The boat handles really good on turns and rides smooth. It feels just like you're floating on the water.
This boat hardly uses any gas and gets up to 50 MPH really fast.
There's room for stowing everything so you don't have a bunch things bouncing around the boat.
There hasn't been a drop of water in the boat yet !
I installed 60 lb SX smart tabs and a Hustler 21" prop.
Now the boat gets on plane in 3 seconds and rides like it's floating on air.
The ride is like riding in a cadillac on the water. You feel very few bumps and at 45 MPH it seems like 20 MPH.
The Hustler Prop gets the boat up to 45 MPH in 5-6 seconds at only 3500 RPM's and 52 MPH at 4200 RPM's.
I had the wife with me so I didn't run up all the way to WOT but at 52 MPH I did push the throttle all the way down and there was alot more left and I felt the boat jump but I Backed down after 2 seconds or so because she was yelling at me.
I would guess the max speed to be 61-63 or so ?
The smart tabs keep the boat level and wakes aren't an issue and now there's
very little movement from side to side going over wakes.
I did have an issue installing the SX tabs because the ski platform comes out too far and it makes for a bad angle. The actuator was hitting the tabs where the holes are and it caused the actuator to get bent. This is a design issue with the SX Tabs.
What I did was cut off four of the holes so the actuator didn't hit them and installed the actuator in the hole closest to the boat. I called Nauticus and they sent me some new high performance actuators which I just installed today but haven't tested yet.
Overall I love this boat at it rides really nice. I really like the high gas milage and the fast cruising speed !
First the bad:
The good:
