jakehardgrave
Thread starter- Joined
- Oct 1, 2012
- 9
Hi guys, I run a small fiberglass repair business in TX. I have worked in the glass industry for awhile but have just opened my own shop. I already seem to have a catastrophic issue that no one can explain.
I am working on a Navy Blue Mastercraft 2008. I know dark colors are hard to work in, but I am a great color matcher and can ussualy make it work. This is the issue: I color match the gelcoat, thin, catalyze, and spray. I come back in the morning and the color is so spot on I had trouble finding my unsanded repair. I then hand block the finish from 400 all the way to 800. I notice the color has dramatically lightened and has reappeared. I proceed to clean it up and buff with Imperial and its sticks out like a sore thumb. I fret and respray it twice more and get the same results. I talked to Spectrum Color about it (using their gelcoat) and their tech guys said what I know to be true. The cured color is the finished color. Not in this case!!! They could only tell me that maybe my Duratec was causing the issue. Called duratec and they said theres no way. could it be an overcatalize being very apparent in the dark color? maybe because weve had high humidity for awhile? Maybe stail gelcoat?
Stats of spray:
Spectrum color match, field tinted to match.
thinned with duratec high gloss 30%
sprayed with preval to sufficient thickness, (the problem is not related to thickness)
sanded with 3m gold 320, 400, 600, 800
buffed with 3m imperial
Please help, this is an expensive boat, I feel like Im in a bad situation, Ive never had a problem I didnt understand with gelcoat.
Stats of spray:
