I have an 18' Campion fiberglass runabout, pretty standard, and I've bought a really nice 4-stroke for it, but wouldn't you know the motor is 25" and the transom is 20". So close, so close.
So, I need to raise the transom a bit. Not such a bad thing, and I'm kinda handy -- though by no means a seasoned boat restorer -- but, sure! No problem, right?
The transom itself I *think* is essentially sound. I assume it used to be perfectly straight across, but after 25 years or so it's only bowed out 1/2" at the centre, which I'm assuming is not SO bad. And it has minimal rotting issues: I cut the top lip of the deck off to have a look, and other than some really minor bits the only rotted area is off to the side and about 5"x5"x0.5", which I can just fill.
So the transom is probably okay, but... that still means I have more than a few options:
1) have someone weld me an extension, with big wide surface area on both sides of the transom to bolt through, and raising a 14" or so section 5" above the transom.
Pros: Minimal work on my part, would be really strong, but...
Cons: not the best looking solution, and I need to find someone to do it
2) clean out an inch or so of the existing plywood and laminate some plywood together to span the splashwell, then glass overtop; turns out the lowered part the motor sat on is exactly 5" lower than the rest of the transom, so this would just make a nice level top
Pros: can do this myself
Cons: strikes me as a bit... weak. I envison a heavy motor with lots of torque mostly attached to the nominally-attached 6" piece of plywood extending above the existing transom... and my new motor sitting at the bottom of the Sound
3) pull the entire plywood section out (from the inside, presumably), laminate a new one, put it in and glass over it
Pros: strong!
Cons: a real pain to do... but in theory I could do it myself
4) go crazy with the chainsaw to remove the existing wood, the seacast it (a la this classic post)
Pros: strong!
Cons: more expensive, a real pain to do, and I'd be throwing away what appears to be a basically sound transom
5) only chainsaw out a few inches down, build a wood cast for the 5" I need to go up, Seacast only the top 8" or so, then glass over top
Pros: strong enough?
Cons: hmmm...
My original plan was to have an extension welded, then an "expert" I know recommended #2, but that's striking me as not so strong. So maybe the metal is good, but then reading here about Seacast maybe that's better... ARG!!! Too many options!
Any thoughts are appreciated, and I can certainly provide more details if I haven't explained it so well. I've been puzzling over this, my new motor is awaiting me in the shop, and the sun is starting to beckon me out onto the water... I need to get this resolved!
Thanks.
rodney
Pros: strong!
Pros: strong!
Cons: hmmm...
Thanks.
rodney
