need help with starter problem
Grumman069
:eek:i have a 1987 75 HP mariner starter spins pops up and hits flywheel and then the bolt just spins and does not turn the flywheel
mla2ofus
Re: need help with starter problem
If, by "bolt", you mean the starter shaft, I'd say the overrun clutch in the bendix(the gear) is shot.
Mike
Grumman069
yeah the shaft keeps spining while the gears stay still while on the flywheel
mla2ofus
From your description I think that's what's wrong. The overrunclutch is part of the bendix. It's a one way clutch that keeps the starter motor from being overspeeded if someone holds the ign key in the start position after the engine starts.
HTH,
Mike
