Need help sealing from water
Glastron Fisher
So I recently bought a 78 glastron hp 150 bass boat with 90 hp mercury. It didn't come with a trailer ad when we switched the boat over to my trailer I noticed some water went inside the boat. After cleaning the boat I noticed the hose to drain the live wells was loose or broken at the back of the boat where it goes through the transom? Well I also rewired the boat and noticed the live well pump had cracked where the pump meets to filter so I removed it and will try to superglue it back together but what do you guys use to seal where it meets the water? I have sOme tubes of loctite sealer I used to build an animal tank do you guys think it will hold up to water?
Trooper82
Re: Need help sealing from water
3M 5200 is some great stuff....real thick and seals great from what I have read and seen...
