Need HELP identifying motor first
Dalejam
Hello all, long story short, was told this was a 2002 Johnson . 50 hp bombider . The welsh plug is the only thing left for tag. I can add pictures if needed but here is a picture of the plug
Dalejam
Dalejam
Forgot pictures
saltchuckmatt
Looks like you posted the same question twice so looks like an innocent mistake.
Those numbers don't help us. Post photos of your engine and we can get you close enough.
Dalejam
Sorry I lost the page , I book saved it now . I was told it was a 2002 ???
So last year the motor was running rough. So I decided to buy the repair manual . I am
Mechanically inclined , so I also download a video from Brandon’s garage that shows you how to adjust the linkage back to factory settings. I also have removed or deleted how ever people put it . I have ran all new fuel lines through out boat. Tank is in the center console . Rebuilt the carbs with OEM kits. 2 carbs . Found out they had 2 diffrent jets in the carbs . Top was to be a 55D , bottom to be a 56D . I have replaced with (2) 55D . I do have a 56D.
The air mixture screws were set to 2.5 turns out , motor will not run . If I spray starting fluid . A tiny amount ( washes out the walls ) it will fire . So that told me gas issue . Took carbs off double checked , all good . Checked spark blue . So figured air screws . So they are turned out 4 turns . It idles it idles at 900 rpm in a garbage can of water . Timing is spot on . Have marked cyl 1 & 2 on fly wheel. And used timing light to
Show they are firing properly.
My question is why out 4 turns ????
Dalejam
Sorry here are the two videos . Grabbed photos last 2
  • IMG_2299.mov
  • IMG_2298.mov
Dalejam
  • IMG_2299.mov
  • IMG_2298.mov
Are you pushing the key in and holding it in while cranking it over?----Simpler to do and the same as spraying starter fluid in there.--Timing at idle is when throttle plates open,------Timing at idle really does not matter and will show correct even with a sheared flywheel key.
Gee, what does the manual specify for initial low speed setting? For my '98 Johnny 150HPV6 the initial setting is 5 turns open. The 80HP motor of that vintage wants 4-1/2 turns open.
Dalejam
If the flywheel key was sheered wouldn’t it be out of time for the magnets are telling the aystem
When to fire properly ?
As for holding the key in for the primer , at this time the primer is not hooked up. I have to replace seal . Don’t is
Not on motor at this time .
Dalejam
So I posted some pictures, can
you tell from them about what year or model ?
Thanks
Dale
Dalejam
Thank you for the reply’s. No matter what I do I can’t get this to idle nicely or even good . It is a 2 stroke . lol. I looked under flywheel seal is not leaking . I have had the motor running and sprayed carb cleaner around motor looking for vacume leaks . Motor never sped up . The timer base and stator read fine with ohms . So you can only rebuild the carbs 10000 times . lol. So the only thing I can think is possibly the charge coil or stator are
Failing intermittently .
Timing shows perfect for TDC CYL 1. I marked CYL 2 on flywheel. That one shows firing on time.
Did the Joe Reevs WOT shows up at 19 degrees as it should . So anyone want to shoot a good idea of what else I am missing . I am hoping to get this resolved .
Thank you all for the help so far .
