jimmbo
- May 24, 2004
- 14,686
Idle speed is set in Gear, under load, and is generally 600rpm, give or take 50rpm. 1100 in Neutral, will do a lot of Damage to the Clutch Dog, and Gears.
Do you have the correct Factory Service Manual for the Motor? If not, get one. It will have the correct Specs and the process of the Link and Sync.
The Carbs are both fully closed at Idle?
