ab59
Ensign
Thread starter- Joined
- May 10, 2017
- 998
Well I been stuck in neutral for a couple of days as we have had our first storm of the season for the last few days . Had two nice days but I had to cut and split wood for the house so no work on the boat. I stuck the gimbal housing through the transom and could not get the rope gasket to stay in the groove the other day and I really screwed up ! I had been using some 1/2" bolts to hold a board over the outdrive hole and got the bright idea to use the nuts from those bolts to draw the housing in to about a half an inch from the stern so I could poke the gasket into the groove and it would hold itself in place . I had the wife in the boat and handed her the nuts which would not go on freely. When I told her I would climb in and see what the problem was she simply said that there was " goop " on the threads and it was ok and began threading the nuts onto the studs with a socket and wrench so I did not check. BIG MISTAKE . We drew the gimbal housing to the gap that I wanted and then one of the nuts acted like it was stripped out and of course it was the last one she tightened . I reached inside the boat and was able to just pull the nut off the stud and then it dawned on me. You probably guessed , the nuts were course threads and the studs are fine threads , damn I can be a jackass sometimes. I should have checked the nuts and studs at the first sigh of trouble but took the word of someone who , although they were doing their best to help , really did not know about such things and I should have NEVER continued on until I inspected the problem myself .
I have been able to screw the original nuts back onto the studs with no problems and I am hoping that I will not be buying another gimbal housing because of this mistake .
I tell you guys this only so you don't do something similar on your projects .
