- Oct 25, 2011
- 25,239
Re: my minor boat restoration...first boat on a budget! 84 dixie ski 19' runabout
Not a waste of time, if you're likely to always be on a budget build, following a completed thread or a substantially completed thread will help you start to look at it as a series of smaller steps. Then 1 day, perhaps not very soon, it'll start looking like a boat again, and before you know it, you're jumping up & down at the boat ramp shooting a cellphone video to post up for us boat nerds to watch
I will likely never be able to rebuild 1 more then a little at a time, spending a little out of a paycheck. It happens. Check some of the threads in the resto section, some of those guys joined before they owned a boat. Lurked around & read thru some threads, bought a boat, found the below deck horror show that is very often the case, and started to tear into it. And years later, some have still not reached the payoff.
Even in the Starcraft (aluminum division, don't ask it's cult like behavior) owners forum, many of those guys are on a 2-3yr timeline and the tinny's are supposed to be a 'quicker' 'easier' build.
None of mine have been back in the water & under power yet. So count your work to date as a learning experience. You were able to use your boat more then once & it brought you, your gear & your guests back safely. I as of yet, can't say the same. And many of the materials you mentioned you'd gotten as leftover scrap from work. So less out of pocket to date as well. The biggest problem was the big question mark as to the current setup's longevity. Did it work, yes. It was for how long...
The crew @ iboats is really helpful & willing to help in anyway they can. But most will attempt to err on the side of safety 1st & above almost everything else. On this, Jig & I rarely disagree.
Welcome. Nice to have you join us, post up questions as soon & as often as you think of them. If it's directly related to the rehab of the boat, post the questions here. If you are having trim problems w/ the motor's power T&T post a thread in the engine forum for your make engine. There's tons of good info there too.
I don't know what engine you're running but if you need a manual you might try here:
I may be wasting my time, because I haven't even checked my transom yet, but I'm reading in the Hull extension thread..............
so I guess reading through to the transom repair is as far as ill get tonight!
http://search.ebscohost.com/
Username: marshall
Password: public
after logon:
Select small engine repair
Select Marine/Boat motor
Scroll down to find your make
