D
Deleted member 340796
Guest
Re: My first boat restoration, I need some guidance - PLEASE HELP!
Ok, here are additional photos of the bottom with damage. There are 2 different areas with scratches. One is pretty long maybe about 3 feet in length but I took the photo of the deepest part. The other scratch is pretty much what you see within the photo. There are a few things on the sides that look like they tied a quick patch job before and I will likely sand down and redo once I am used to working with PB, they are more cosmetic than anything right now.
Photo 1 here is the crushed look. It seems pretty bad at first but on further look, only the one end goes into the glass under the gel coat.
Photo 2 is the longer scratch I spoke of above. Maybe 3 feet long but this is the worst of it.
Photo 3 is the smaller scratch but I did notice after flipping the boat that it has a crack through it too.
Photo 4 is my early work. Forgot the design of the hulls when I first started cutting the floor out. OOPS.
Photo 5 is a perfect drilled spot that is under the captains area. I am wondering if this could have been a hole used for a fish finder or some other type of fishing device. Any thoughts???? I would like to put a fish finder back on the boat, but I will have to buy one. It did not come with one. I am not sure how they hook up yet or what goes in the water or any of that. I really have not looked that far ahead. If I can use the hole great, if not I will just fill it in. What do you think?
Also on the outside of the transom I see a very worn item that I believe was an old Pitot assembly. Does that have to do with a speedometer guage? I am wondering if I should plan on plugging that hole too while I am at it.
Can't wait to hear what you all think, and what my next course of action is for some of these areas. I can not tell you how pumped I am to get busy on this now that the boat is upside down! Thanks guys again for your time.
