fishfeatures
Thread starter- Joined
- Mar 29, 2011
- 743
Re: My 60hp Johnson on Kerosene ... is it possible??
Nice post thanks for that Machinist. every little bit of positive info helps.
It may be a non runner as we have seagulls over here but none I've seen run on Kerosene, but man i think it's worth a shot.
In doing research when writing my "LeeRoy's Ramblings" for OMC 9.9/15hp motors, I came upon a few tidbits of information on running these motors on kerosene.
Nothing I can find directly from OMC however. But mainly from Australia & yes what "fishfeatures" mentions is just what I came up with. One report from a marine mechanic that got one in for repair was that there was a small gasoline tank under the cowling with a shut-off valve to use for starting, then when warm, shut that valve off & the kerosene one on. He also said it had a thicker headgasket, but never removed the head to see if it was a thicker one or 2 regular ones.
I think using a small fuel tank & OMC quick coupler to start the motor with & changing over to a main tank coupler would work great.
In all my parts list examination I have never found a headgasket labled for kerosene.
Now think about the British Sea Gull motors. These ugly motors are used mainly on long range sail boats & are strictly kerosene. The word was kerosene does not deteriorate over time like gasoline & is not as volotile (dangerous in confines when at open sea).
I see no reason for it to not work & also require no fuel/oil mix. May not have the same power as gasoline however but will give a heck of internal lubrication.
As AlTn said google, "kerosene outboards" & come up with this or http://www.marineenginedigest.com/specialreports/kerosene-outboards.htm
Keep us posted if you do this !!!!!!
