Mounting 2 Transducer's
Capt Sully
Could you mount 2 of them side by side on the same toon on the rear mount bracket ? do you think they would interfere with each other ? Also, what about mounting one on the side of a toon, like on the inside under the helm ? One is for speed and temp, the other is a fish finder / GPS. Thanks,
Silvertip
Honorary Supreme Mariner
Re: Mounting 2 Transducer's
They can be mounted along side each other. It is two locator (sonar) transducers that would bugger each other if mounted side by side.
BobGinCO
Depends on their respective frequencies.
My single transducer on my Humminbird 385ci does all that including two different sonar frequencies that can run simultaneously - something like 83 KHz and 200 KHz.
Boss Hawg
Just courious - Your GPS shows speed- Most any fishfinder shows temp- Why two?
Your fishfinder/GPS should do all you want.
Capt Sully
On the boat now is a dash mounted gage that shows only water temp and speed. I'm going to install a Fish finder / GPS unit also. I would like both to be working.
