1980 Mercury 40 hp outboard tach problem
YN2(SS)
I have been working on this outboard and the tach was not operating when I first got the outboard running. The electrical system was not charging the batter and I found a bad regulator/rectifier. I replaced that and now the tach is doing this. When I pulled the wiring harness plug out of the from of the remote control, I found some corrosion on the grey tach wire hole, and have not had a chance to correct this yet and test it. Any other thoughts?
http://www.youtube.com/watch?v=8KPzNgI7MxM
YN2(SS)
Re: 1980 Mercury 40 hp outboard tach problem
Has anyone seen this problem before or know where to start?
petryshyn
The stator may be failing.
Tach could be bad.
YN2(SS)
How would I test if the stator is failing (follow test in Seloc manual?/ I'm not seeing any other symtoms (i.e. o/b runs good, charges good, etc.))?
How would I test the tach?
If I need a new tach, what do I need to know to order one? Someone said I need to know the number of poles on the stator. I believe I counted 10. Is that all?
YN2(SS)
As a follow up, this tach problem has been there from the beginning of getting the boat in the water, and now I have a new problem which I am wondering if it may be related. See thread
http://forums.iboats.com/showthread.php?t=355455
I guess I need to man up and figure out how to accurately test my:
tach
stator
switchbox
Any suggestions?
