Re: Motor mount rot/89 Reinell Restoration
It's impssible to give an exact "Quote" of everything you'll need but this list will get you "Started" and from there, after you've done some "Glassin" you should have a good idea of what you'll need to "Finish-UP"
Here's my take on the Starting List for a boat of your size.
PPE
Respirator (Full Face Preferred $100) if not then double filtered 1/2 face and Goggles with vents taped over.
Latex Gloves (1 – 2 Box(s))
Leather Gloves 1 Pair
Full cover Hooded Tyvek suit. (Rubber Band or Tape the Wrists and Ankles, wet Towel around your neck)
Talcum Powder (coat yourself TOTALLY with talcum powder prior to every grinding Session. This really helps seal your skins pores and keep the "Itch" off.)
Demo Equipment
Prybars, Hammers, chisels, Putty Knives
Flat tipped shovel to remove foam, Old Carpenters Saw (The Old Fox Hole Army Surplus Shovels work well)
Circular Saw
Sawzall
Dremel Tool
Router
Drill
Random Orbit Sander
Rasps, Files
4 1/2" Grinder with Backup Pad and 3 dozen 24 grit resin coated sanding discs
Masking Tape
Shop Vac for dust control or Dust Collector if you're fortunate enough to have one. It's good to create a Plastic Tent over the boat to contain the dust. There WILL be a LOT of it....A LOT!!!!
Glassing and Wood Products
3-4 sheets 3/4" Arauco Ext. Grade Plywood
(Possibly some ?” and ?” for side panels and seat bases when and where needed”
15 -20 Gallons 435 Polyester Resin
4 Gals Cabosil
1 lbs 1/4" chopped strand fibers
25 yds 1.5 oz CSM
15 yds 1708 Biaxial Cloth
2 dozen 1 qt plastic mixing buckets and stir sticks
1 - 1/2" x 5" Fiberglass "Bubble" roller
2 dozen Short nap 6" nylon roller covers and trays
2 dozen 3" Chip Brushes (cut ? the length of the bristles off)
