Motor change
Miketheboater
I have a 1995 19.5 ft searay witha 3.0 lx mercruiser.What would be involved to put a 4.3 or bigger in this boat.I'm new to boating and I.m thinking i should have done more research before buying with this size engine.
Re: Motor change
Ayuh,... Sell it,+ Buy another 1....
It'll cost Twice the hulls value to refit it to Bigger Horsepower....
Miketheboater
Re: Motor change
You mentioned refitting the hull for the bigger engine. On the searay website a bigger engine was an option for this boat?
Re: Motor change
Ayuh,.....
You Need,... EVERYTHING from the other driveline...
Then your hull will need different motor mounts,+ what nots...
The motor,+ outdrive you have now won't just swap out to something different...
Outdrives are geared to different motor Horsepower outputs...
Miketheboater
Re: Motor change
Hello!! yea that could get exspensive. I guess searay would have done all that if you went with the bigger motor option.
Re: Motor change
Ayuh,... Searay,+ Everybodyelse buys Power Packages that include the Complete Driveline,...
Then build a hull around it....
Miketheboater
Re: Motor change
Well that bites hard. The boat does 40.3mph on the GPS i guess i'll have to live with that. Thanks for the info guys talk again i'm sure happy boating.
