Moly grease substitute?
GMTK
Getting ready to replace the bellows on my 2004 SX-M. In the shop manual, it says when replacing the sterndrive, to "lubricate the driveshaft splines with Molybdenum Trioxide (Moly) grease.
I have the volvo grease for the splines on the prop, but can't really find molybdenum trioxide grease. This is the closest thing I have found: https://www.napaonline.com/en/p/VAR632
"Valvoline Moly-Fortified Multi-Purpose Grease Is A Superior General Grease Fortified w/ Molybdenum Disulfide To Provide Excellent Extreme-Pressure & Anti-Wear Protection For Disc-Brake Wheel Bearings, Chassis, Suspension & Universal Joints."
Any suggestions on this are welcome and appreciated.
robert graham
Maybe some of that special black molybdenum grease used in constant velocity universal joints?......that's what I use in my VW rail buggy CV joints.....it's fairly cheap and available in about 6 ounce packages....just an idea...
CV boot grease or driveshaft spline grease
GMTK
Or this:
Ayuh,.... That'll work just fine,.....
Most all chassis grease has moly in it,....
The Merc grease ya linked too, is teflon based, 2-4-C which will also work, but is thinner, with less "Stayin' power",...
I use plain ole Napa chassis grease,...
BRICH1260
I`ve used OMC triple guard grease and Merc Quicksilver for my driveshaft splines in the past and have had no ill effects.
