Minn Kota Power Drive 55 prop stop working...
2nr Guy
I have an 2004 MK PD 55 w/ auto pilot that the prop stop working last wkend. The trolling motor will still turn in directions, show battery life, auto pilot still works, but prop will not spin. When I press or turn on the foot pedal it will make a clicking noise from the control board, coming from the relay. I hookup direct power to the motor and the prop works and will spin. Sounds like a faulty control board, so I order a new board w/ brush kit. I received the parts and installed the control board, brushes, bearings, and seals just to be on the safe side. After I installed all the components, hookup the power and the prop still not working. So I hookup direct power to the motor again and it spins like it should, so I know everything is hookup right including the brush kit. So my question is? There something holding back that it's not letting power to my motor or did I receive a defected control board??? Also is there a way of testing these control boards? Lmk thanks. - Allen
jsawyeroo1
Re: Minn Kota Power Drive 55 prop stop working...
Did you ever figure out the problem with your trolling motor? Mine is doing the exact thing.
2nr Guy
Yes, the new control board was a defect. Couldn't return or exchange it because it was a electronic part, so I had to purchase a second control board. Also check your speed on your foot control that is not on 0, or the prop won't turn or work. Hope this help, thanks Allen.
