Mid 80s Yam 70 hp idle ???
rdm429
Have a 86 70hp yami outboard which was completely rebuilt last winter have ran about 30 gals of gas thru at this point with a premix of 50 to one in addition to the factory oil injection for the first 20 gallons, the motor runs very well except prolonged idling or trolling carbs were cleaned with a sonic cleaner,floats have been set and rechecked. I can get it to idle down to 750 rpm but at that engine speed it idles rough an stalls after a few minutes, have had low speed screws from less than one turn out all the way two a couple turns out,manual says 1 1/8 to 1 5/8, have also tryed moving mechanical advance back an forth couple degrees with no luck, compression is 118 bottom 120 middle 120 top, also running amsoil marine 2 cycle oil in premix tank.. Are these engines able two idle that low or what, manual says idle speed is 650-750 rpm. Was told by local marina that I might have to go up on the low speed jet due to the ethanol in todays gas. Also running a 13 pitch prop which is a little under propped , 5750 rpm at top speed so dont think theres too much drag on engine at idle.. Anyone have a idea as to were to go next.. thanks..
99yam40
Re: Mid 80s Yam 70 hp idle ???
what is the timing spec at idle on that old motor?
and what is the motor running at?
If all in spec and good spark the fuel pump may be leaking into crankcase, too much fuel is like too little the cylinder will not fire properly
carbs are not as clean as you thought,
or you have a leak between cylinders
top or bottom seal is letting air in
rdm429
Thanks for response 99yam40, timing spec at idle 6-8 degrees atdc which is right on, has strong blue spark at cranking speed, has brand new oem fuel pump, carbs were cleaned with sonic cleaner and checked, look like brand new.. thought about air leak to,all three plugs are burning the same, perfect plug color...this has me stumped..motor does not smoke much even at idle but is using oil from oil tank, also tried going to a hotter plug with no change b7hs as opposed to standard b8hs..
99yam40
All I can say is that if the carbs passages and jets are really clean and the link and sync has been done, the factory setting on pilots screws should be good to go
rdm429
Think at this point going to order rebuild kits for carbs and see if that helps, have had carbs apart 2 times ,dont think they could get much cleaner,maybee the new needle an seats will fix issues, thanks for replys..
