aksor
- Apr 21, 2009
- 150
Hi guys and gals
I just bought a 94 Sea Pro Renegade jet boat with the 90 hp Mercury Sport Jet for $400.
The lady I bought it from said it starts then shuts down she took it to the marina and they told her it will cost her $2000 to get it fixed.
When i got it it was missing the flywheel so I took a chance with it not even knowing if the motor was seized or not hence the price i paid
I found out where she had it serviced and recovered the missing flywheel and also talked to the mechanic and he said fuel was spitting out of the carb's so he said it points to damaged reed valves
So i took the intake apart and took the reed valves out for inspection none are missing petals but out of the 3 2 of them one side don't seem to seal properly if I point them toward a light source i can see light shining trough!
My question is do I need to replace them or are they still good for a while? Would this cause the start then stop issues I'm having or is it the magnet that came loose in the flywheel and was still there but there was no gap between the two magnets.
BTW the compression is good in all 3 cyl and the carbs are clean the vent elbows had some gunk in them but cleaned them out along with the vent hoses
I also noticed that the ride plate was not flush with the front of the hull so i removed it and straightened it out.
My other question is can I run the engine once I get it going without the ride plate in place to prevent another bend in case it backfires while I'm testing the engine?
Thanks
Thanks
