staring issue. we had been on the water a while and actually moved several times with no issues. then on the final move i went to start the engine, and it wouldn't do anything. the buzzers, guages, tilt trim every thing worked, except no engine turn over. i moved the throttle control forward and reverse several times, no change. after loading the boat and just for kicks i tried the ignition one last time. the motor fired right up?
Is there some sort of nuetral safety switch inside the controller?
2001 Mercury XP150
Side Mount Controller Mercury 300 on the label
2000 Triton SF-18
the controller does have the push in button that lets you use the lever for the fast idle.
any suggestions?
2001 Mercury XP150
2000 Triton SF-18
any suggestions?
