marine59901
- May 18, 2012
- 6
I have a 1986 mercruiser 140 3.0 that has really been frustrating me. I have checked for fuel and it is getting fuel. I have replaced the coil, coil wire, points, dist cap, rotor, condensor and still nothing. I have 4 wires going to the coil on the positive side I have a purple wire that looks like it goes into the main wire harness and I have a purple with yellow that goes to the starter. On the negative side I have a grey wire that I assume is the tach wire and than a black wire that goes to the dist. I get a full 12 volts to the positive when key is on and get 7.5 to 8 when you try to start it. I removed the grey wire and still doesn't start. I have charged the battery I have checked the ign switch and all seems to be fine. I hooked up a spark plug to the coil and ground it to check for spark and I couldn't see any not sure if It would but tried anyway. I checked for rest on the coil with all wires unhooked and got rest. I am really stuck and would like to know what to try next. I don't have a history on the boat we bought it in the winter but it was prof winterized. Good lesson to look for boats when you can start them up lol but any help would be greatly appreciated.
