Merc dry joint on a VP motor???
Lubak572
Can the Merc dry joint manifolds be run/adapted on a VP motor? Anyone done this?
alldodge
Don't see why not, just need to adapt.
Which motor do you have?
Lubak572
5.7 GSIPEFS had water intrusion looking for better options when I replace motor. Hytek Marine, etc.??
alldodge
You can use Merc or VP, and if intrusion was caused by rotted out mans/elbows, then that is just time. If it happened do to ingestion form exhaust, then may need to increase riser height if space is available
Believe angles are different
I would go with CMI before hitek
May simply need a riser. What is the riser to SWL measurement? Should be 14"
