3 to 7 should be fine. You will probably have to "T" in the oil pressure switch. There should be three pins on the oil switch. Common that goes to the relay. One that is normally closed that goes to the start terminal on the slave, to activate the relay during starting ( not the coil side), and one normally open that goes to the ignition ( the choke wire is a good place to pick that up). The large "hot" terminal on the slave is a good place to pick up power to the relay for the pump, or directly to the battery if it is closer. I used a similar relay for my Petronix. I mounted it using one of the valve cover bolts, worked fine.
