bds85466
Thread starter- Joined
- Jun 11, 2007
- 375
Hi Fellas,
I got a call from a buddy who was stranded on the opposite side of the lake. He has a Merc 140. Said he had been running fine for about 3 hours, idling and WOT etc. Then in idle, it began to sputter and die. He couldn't keep it started unless the rpm's were high, and then when he'd lower them to switch into gear, it would kill.
He couldn't get it into F, so he paddled to an empty slip and parked. I went over last night to look and it was the same deal. Couldn't stay lit unless the rpms were high. Choke/spring appeared to be working correctly as it heated it opened, as it cooled it closed -- so I'm thinking more carb/jet related?? Something worse?
Any carb experts out there to shed some light? Possible adjustment or need for rebuild?
grainy pictures are more to show which carb it is as I didn't pull the model.
