imported_TheMan
Thread starter- Joined
- Oct 19, 2006
- 224
Alright, one of the strangest things I've ever seen and I'm leaning towards it being abnormal..
I couldn't get the engine to start and figured I flooded the engine, so I pulled the plugs to dry them out and turn the engine over a few times to expel what gas I could. (The engine did start after I put the plugs back in, but thats not the point)
I disconnected the coil to distributor wire while I was turning the engine over.
While doing this, a high energy spark would travel from the coil plug to either the positive or negative terminals of the coil fairly regularly.. I've never seen anything like this before and am wondering what, if anything, it might mean. It seems that without the distributor connected to trip the coil, it should not emit a spark, but I am not sure if there is any variation from my other experiences due to the thunderbolt ignition system. I'm also not sure why the spark jumps to either the positive or negative side instead of just the negative side..
It is a '90 Mercruiser 4.3L with Thunderbolt ignition. Anyone ever see anything like this before or have some input?
Thanks in advance.. I might take a video of it just because it is kind of impressive..
