Woodonglass
- Dec 29, 2009
- 25,932
Re: Marine Grade Plywood Debate Thread...
I have done a LOT of reading on MDO and HDO and it has been used in boat building since the 50's. Both above and below the waterline. Chris Craft and Owens used in in some of their boats. In all fairness it has mixed reviews with some loving it and some not. If you want to learn more just Google HDO and MDO in Marine Use and you'll find plenty of reading material. I will continue to consider it as an optimal product to use for boat restoration until someone can definitively show reasons why not to. Again, for Me, the pros, outweigh the Cons. But, that's just me.... to each his own. Epoxy adheres to it very well and as long as you use a layer of mat between laminations using poly you should have no issues with adhesion. You should shear wood before the outer resin facing fails.
Oh, I guess you all can tell, I really like this stuff!!!
