Re: Making Fiberglass shine again
Why cant you get these out>? I have on the side of my hull where the letters were you can see the difference, Why cant you uselike an 800 grit here and then step it up to a 1000 in this area and then buff it out? I dont see why a good buffing wouldnt take it out anyway. You thoughts?
Because when the boat is new and the decals are put on. The Fiberglass and Gel coat are new. Fiberglass fades and oxidizes from Sunlight and UV rays. When you sand or polish you actually remove some of the Gel Gloss/coat but you can never bring the fiberglass back to it's original state unless you take it all off and apply a new Gel coat. The shadow will always be there. I know some people think well it will age and fade with the sun and eventually blend in but that's not true because the parts where the stripes, Decals, Boat Letters, Boat Name, State Registration stickers were not, will also fade as well as the protected ares by the stickers. I have found the best process for restoration to be.
Follow the manufactures instructions to the letter.
1- An acid wash to rid the fiberglass of oxidation is necessary.
2- If Oxidation is bad? You'll know it when you swipe your hand and you get oxidation on your hands or clothes. Use 3M Color/ Gloss restorer # 09089
3- If oxidation is light use 3M 09009 wait two days and then wax again.
4- If you use Use 3M Color/ Gloss restorer # 09089. After the boat sits for a couple days to harden. Then use a good Marine Wax before ever putting it in the water. Wax- Wax-Wax. Or you will be back in the same boat in a couple years. Pun Intended. A good rule is wax in the early Spring, Mid summer and late Summer. Then after twice a year Spring and Mid Summer.
I've tried different products and have found these to work the best. I don't have time or the energy to try products that don't work.
"Chuck's Fiberglass and Color Restore"
With all that said and I know I'll get some repraisals. I just know what works.
Use a Commercial Variable speed buffer starting slow and increasing your speed. The walmart waxer and Polisher won't last even half the boat.
The Deadliest thing to Fiberglass is UV rays. The wax protects the fiberglass from the UV Rays. The hardest thing on a Fiberglass boat is sitting on a boat hoist all summer because it not only gets the rays from the sun directly but it also gets it bouncing off the water. So the boats on a hoist get a double wammy. If I were to keep a boat on a hoist I would cover the boat all the way to the water with a tarp. Maybe using milk jugs filled with water and tied to the grommets of the tarp.
No I don't work for 3m
Now you have just had a brief lesson in Fiberglass care and repair. Oh the 3m
products probably can be bought at your local Marine Dealer but they are
not cheap. So the decision to remove stripes and decals are up to you. As far as the Shadow though. You will just have to live with it.
