Flynn18
- Feb 16, 2017
- 8
i recently purchased for $550 a boat that i do not know much about: the previous owner told me that its a 1986 mirrocraft musky(or mister musky) with a 1986 johnson 75hp outboard (according to the model number(E70ELCRD) i believe its a 70hp from 84)
He was selling it saying that the boat was free and i was paying for the motor and trailer, the hull has a large dent(~1.5ft dia) on the bow just above the waterline, i do not know what caused the dent but it is about 3in deflected at the deepest point, the dent is right over a riveted seam and has caused a + shaped crack about 2in by 2in about 5in below that seam. I have heard that Mirrocraft is a lower quality boat so i am seeking advice on whether or not it is worth it to repair or have this repaired.
i do some welding(steel only) and fabrication out of my garage so i will do any prep work that i can to minimize shop time/cost
if i bring it to a marine shop i would like to have it fully stripped and ready to be welded
I have a friend that is an experienced aluminum welder and would help me out, but i am worried about the aluminum becoming work hardened and brittle from stretching(denting) and then being forced back to its original shape, i have thought about cutting a large X or + into the dent, then bending it to shape and having it welded and reinforced like that but that will be a lot of welding and heat and may heat treat the metal and make it brittle. is this something that must be performed or at least looked at by a marine repair specialist or am i overthinking it?
so my question is should i:
a)hammer or jack the dent out and have the crack welded and reinforce the area(if this is a good option, should i do this with or without heat?)
b)cut an X or + into the dent and bend it to shape then have the cuts and the crack welded and reinforced
c)scrap this hull and find another
should i attempt to do this repair with my friend welding it or should i leave it to a marine welder?
Please note that this does not need to look pretty inside or out, i haven't had it on the water yet but judging by how much sealer is on the boat I'm sure it has many leaking rivets, the previous owner told me he'd kept using the boat even with the dent and crack because the bilge could pump water out much faster than it was coming in, especially when lightly loaded.
I would also like to know what you guys think the boat/trailer/motor are worth, and if you think it will hold up to being in the Long Island Sound or if i should only take it to greenwood lake
Please let me know what you think
