Lower Unit Oil
JakeCo88
Can anyone tell me what type of lubricant I need to use in the lower unit of my 1956 Evinrude Fastwin 15. The only thing I have found online is Lubriplate #105 white grease, but I also found that is not recommended for engines with a shifter. Any thoughts?
Joe Reeves
Re: Lower Unit Oil
Outboard gearcase lubricant "HiVis" 80/90w, available at EWal*Mart, K-Mart, dealerships, marine type stores, etc. It'll state HiVis gearcase oil on the container.
kfa4303
Banned
Re: Lower Unit Oil
+1. Here's a pic. You'll probably want to get a pump too. They should sell them right nest to the oil itself.
boobie
Re: Lower Unit Oil
Don't ever use the Lubricate # 105 in that g/c. It was designed for mtrs a lot older than yours.
JakeCo88
Re: Lower Unit Oil
Thank you very much gentlemen. Another question: when I dropped the lower unit, the o-ring at the top of the drive shaft was seriously damaged. I don't really see the point of it in the fist place. Is it okay to put it together without the o-ring?
lindy46
Re: Lower Unit Oil
If you omit the o-ring, water can ride up the driveshaft and get to the crankshaft. The result will be a driveshaft rusted into the crank. You don't want that to happen.
Joe Reeves
Re: Lower Unit Oil
Lindy & Frank said it all.... Install that new O Ring and grease the splines!
boobie
Re: Lower Unit Oil
But don't put any grease on the very top of the splines.
kfa4303
Banned
Re: Lower Unit Oil
The o-ring comes in a lower unit reseal kit along with oil seals, spaghetti seal and the Drain/Vent washers. You can get a kit right here at iboats for about $20.
