lower unit 1988 alpha1 140hp inboard
suetimbrit
I am having problems with my 1988 alpha1 inboard motor. It is a 4cylinder and 140hp. I was pulling a skier last summer and the prop hit a log. The mechanic said the prop had been spun and he fixed that problem. However when I took it to the lake it idled fine but there was a very loud grinding noise and the boat wouldn't move. The engine also began to miss and die and the entire boat vibrated. What could my problem be and what do I need to do?<br /><br />Thanks<br />pipeman23
Don S
Re: lower unit 1988 alpha1 140hp inboard
Drain the gear lube from the drive and look for metal on the drain plug magnet. If it looks ok, pull the outdrive, hook up a water hose to inside hose from the transom shield and run the engine again. I would bet your drive was also damaged. Prop that hit logs at high rpm and loose the hub, also cause drive damage.
suetimbrit
how do i remove the lower unit from the boat in order to get it repaired??? thanks for the help so far but i am still lost.
