Holdemhook
Thread starter- Joined
- Apr 11, 2014
- 20
Hi I recently replaced my plumbing to my live well, the drain is located under the water level and has a thru hull fitting with no type of a check valve, when the boat is on the water I can see water in the drain of the live well so obviously the entire hose is filling with water. This doesn't seem correct. Am I suppose to have a in line check valve or is the drain hose suppose to be routed so there is a loop above the water line ? I reinstalled the new hoses the same way the original ones were. Thanks in advance.
