Re: Link and Sync 85 hp v4
Iplayed with the timing and it didn't make a difference, the problem is that at idle the motor fires on all 4 cylinders and runs very sweet, as soon as you give it any throttle two cylinder foul out instantly but seemlike at wot they start firing again. Here is what I have done, new coils, cdi boxes and stator. Rebuilt carbs and new fuel line and primer ball, also checked fuel pump and it operates perfect, all cylinders have great compression, 127psi, 130psi, 127psi, 125psi. What now?
