Kill switch replacement
AlThePal78
So the kill switch I'm replacing. I'm trying to figure out where would I put the actual black and yellow wire cuz I do not see another one with the other boat wires? Additionally, the original kill switch was purple wires with a purple and white wire as well.
AlThePal78
Should I wire it into the yellow n red somehow or the purple ignition one?
brodmann
There should only be two wires. Are you replacing the lanyard switch? All that switch does in ground the ignition system. Again there should only be 2 wires and it makes no difference which one goes where. All that does is make a connection if the clip is pulled out. What are you replacing exactly, and what are you replacing it with?
AlThePal78
Yes I am replacing the lanyard switch. I don't know where the second wire connects too. Is it the yellow red one or purple one? That is all I need to accomplish because it is back on
AlThePal78
There is no black and yellow wire indignation switch here so I didn't know where to connect the second switch
04fxdwgi25
Probably can start by indicating what propulsion system you have.
Different between the outboard and sterndrive.
PS: That ignition switch has been bubba'd. Suggest installing proper sealed ring terminals on the wires and reterminate
04fxdwgi25
For the I/O system. Yellow / red are for the starter neutral safety switch. Purples are for the kill switch.
there are two types of kill switches. Three if you count the combo switch
those that are normally open and held closed with the lanyard. these are for I/O's and powered ignition. when you pull the lanyard, it breaks the connection. these are normally in the purple wire
there are also the normally closed and held open with the lanyard. these are for magneto ignitions on outboards. these tie between black (ground) and yellow from the magneto. this shorts the ignition to ground thus killing the outboard
and there are the combo switches with two connections. depending on application you only need one.
based on your first post
you have a switch for an outboard and based on the wiring, it looks like you have an I/O
AlThePal78
Yes it's I/o
AlThePal78
So I have an inboard/outboard or stern drive, it is a sea ray 180 bowrider. I can't find the second purple wire that related to the kill switch. I bought the run/off switch but it was the black ground and the black and yellow. I thought it would do the same thing. I now need to replace a bunk on my trailer the bunk must be old. I don't have anyone that can drive my boat long enough so I can replace it myself. So now I am on two different problems.. I need to buy the proper kill switch and then I have to find the second purple wire. Then I have to repair the bunk. More then likely I will have to replace them both.
04fxdwgi25
Ones with the black wires are for the outboards.
As shown in the diagram, the purple feeds the ignition, with the lanyard switch in series in the circuit. In your 1st picture, you show a purple wire with a connection on it. Break that connection and install the safety switch in between the 2 wire ends.
To test and prove the switch out: Put an ohm meter across the switch leads and trip the safety lanyard. If the meter goes from closed to open, it will work for I/O's to open the ignition circuit. If the switch goes from open to closed, it is for the outboards to ground out the magneto.
AlThePal78
To test and prove the switch out: Put an ohm .
So you are saying, that purple wire, needs to be cut and spliced, then in one side put it through one side of the purple wire to the switch , then the other side if I had the proper switch okay I get it now
It's one purple wire. The connector shown in your first picture. Disconnect that connection and put the switch in between the two connectors
Use a hydraulic jack, some jack stands and some pieces of 2x6 to lift the boat off the one bunk to replace it
AlThePal78
I'm going to need help with lifting the boat I don't own any of that equipment to do so.
