Keel re-build and/or protection
fmjnax
I just bought another late-80's Skeeter fiberglass bass boat (2 years ago I had finished a full blown restore on a mid-80's Skeeter). It's in much (MUCH) better condition than the last one I restored, so I'm not going to be doing a full-blown restore on it; basically, just a cosmetic restoration is all that is needed. All wood is solid and a drill test on the transom produced dry wood. Not really surprising seeing that I am the second owner of the boat and the first owner [a family friend] kept it well maintained.
So, with that stated, the only structural damage the boat has is along the keel from nearly 25 years of beaching. Visual inspection does not appear to show where the fiberglass was ever worn all the way through. The previous owner had bought some poly resin to build it back up. The resin build-up does not have any soft spots or cracks. I ran water down the inside of the keel from the bow to the bilge by sticking the garden hose in through the trolling motor access panel. No water appeared on the underside of the hull. I THINK it's a functionally solid repair.
I don't particularly want to grind down the resin and do any major glass work. The boat will have to stay on the trailer, but it's not a roller trailer so access isn't a problem. I really just want to throw down some sort of keel protection and call it a day. I am going to be using bed liner to "repaint" the trailer and thought I could use a little of it to roll a strip down the keel. Two birds with one stone, pretty much. I know that WoG has been referencing a member that used Herculiner as a keep protector, but haven't seen any results yet.
Another option I have been exploring is to grind down some of the resin and build it back up, but pigmented to match the hull (gray) instead of leaving it clear. Is this even possible to do? And, of course, there is always the keelshield/keelguard option, but I am trying to stay away from having to buy one of those.
Any thoughts on the matter?
if your water tight, buy a keel guard and go boating
greenbush future
I wouldn't paint anything on the outside, with the idea off waterproofing it. One day that will need to come off, that may be why they sell the rubber guards that are removable. If it isn't broke, don't fix it?
Woodonglass
No results have been posted on the "Truck Liner" keel guard. Having said that, If I had a bass boat, or any boat that I was considering beaching on a regular basis, before I spent the High Dollars for a Keel Guard, I WOULD be experimenting with the Truck Liner to see how it held up. Not that much money and if it works GREAT!!! If not then scrape it off, lesson learned, and buy the keel guard. Again just the opinion of an Old Dumb Okie!!! Your boat...Your decision!!!;)
fmjnax
Thanks WoG. That's pretty much the same mentality I had. I'm not going to run it down the entire keel so it shouldn't have an impact on performance when I'm on the pad. I will technically already have the product from the trailer project, so it won't really cost me anything. I don't think it looks half bad either, so why not? If it doesn't work, I'll paste a $200 keel guard on it. I just wanted to make sure it wasn't going to have some devastating effect, like easily peeling off or turning green or something like that.
The more I think about it, the more I think I'm going to give it a try. If I really screw it up, it might be the perfect opportunity to convince the wife to let me learn how to spray gel coat and refinish the whole thing. :) I would be doing it within a month and will be on the water so perhaps I can get some real-life results on here sooner than the other guy will be able to.
JASinIL2006
I'm interested to hear how it works. I was going to go that route -- I even bought a quart of Herculiner - but I chickened out at the last minute and bought a KeelShield (from iboats, of course!). I was worried the Herculiner might not provide enough protection and I had concerns about removing if that was the case.
If you apply this stuff and post your results, you'll be the first (that I know of, anyway), and I bet lots of other would benefit. I hope it works!
fmjnax
I'm going through with it! Will most likely do it over the July 4th weekend. I bought this boat for $500 (an absolute STEAL!) and put $200 in to it to get the lower unit working again so what do I really have to lose? :)
