chevymaher
Thread starter- Joined
- Mar 29, 2017
- 2,938
Introduction first. I am Randy from northern Ky by the ohio river. I grew up around boats but this is my first one.
I keep coming across this forum researching my new boat. So I figured I going be here alot and decided to join.
Now the boat in question. A 87 Four Winns 170 Horizon. And like my chevelle I got it in pieces and in boxes. The boat sat for years and years neglected.
Guy said last time out skiing it ran worse and worse until it died. He pulled the engine and outdrive. Planned on rebuilding it. Then got another boat and it just sat.
I got the engine and outdrive here a month ago. Had the engine on a stand in the shop seeing what was wrong. I got the boat itself here a week ago. Had to wait till the mud in his yard dried enough to pull it out.
I plan to fully restore the boat as I go along. New interior make it presentable. It is a 3 liter merc and I have ridden in one my buddy had I am fine with the power. I will be fishing and skiing not racing it.
So far I found a dead spark plug wire. The electronics in the distributor shorted and they are gone. A pertinex unit. It had a bad coil. Distributor knife edged the gear. And it had way to much side play in the distributor shaft. Seems Merc did not use a lower bushing in them. Or it was a factory mistake. I restored a 68 chevelle so I had lots of parts to that. I pressed in a lower bearing in the distributor housing solved that mess. It says it has 64 hours n the engine on the counter. Boat reflects that this may be right. It has no wear anywhere. Seems it just sat.
The boat its self was stored correctly with the plug out. I checked for rot all the wood looks good. Interior was badly mildewed and the exterior was moss and mildew covered from sitting under the tree for years.
I am a registered car mech and I do paint and bodywork. But am new to the gel Coat situation. And this is why I kept coming across this forum. Learning Gel coat care.
Any how I sanded it and buffed it on the extremely faded color stripe. I still got the white to do. But is looks alot better. Future post will not be so long winded. Just had a lot to catch up on this round.
I don't expect to float it this year. Shooting for next summer. But who knows if things go well.
Here some as I got it and now shots of the Barge as I call her. Never mind I just found out I have to make 3 post to do that so in the future I will. The saying on my other forums is we like pics. I assume this one is the same.
Randy.
Randy.
