Johnson seahorse 1965 ?
155truck
I bought a Johnson 6hp seahorse off a freind,it was just laying on the floor in the corner of his garage w/junk piled on it.Didnt get a manual or any information on it. Model # CD-22M , Serial # J 2526682, I think it's a 1965 but not sure, can anyone tell me if I'm right on the year an need to know the fuel mix and spark plug gap. Thanks for your help.
155truck
Re: Johnson seahorse 1965 ?
Thanks Tashasdaddy,I did get the motor set up in garage this evening.Put a 5 gal. bucket of water under it,mixed some 34:1 fuel and it fired 3 to 5 pulls sounds great.Awesome, I'm going to take your advice on the oil and check the other things out to.Thanks for your advice.
tashasdaddy
you need a bigger bucket!! the water has to come 1/2 up the leg for the water pump to prime. your oil mix is 50:1. i use a garbage can.
155truck
Not to worry had my bucket up high enough,water pump works great.Thanks again for the help.
Vic.S
Plugs should be J6C gapped 0.030"
155truck
Thanks Vic for the gap setting,more info I can use.Have a manual ordered an I'll be set to go.Thanks guys for the help.
