Jet Boat needs help
JetboatKid
Hello i have a 1974 jet boat with a 468 chevy big block in it. it is going to be a 10.5 to 1 motor pushing about 450hp to 500hp. i need to know what impellar to run in my berekelly 12jc pump. The impeller that is in it now is a AA. thanks
NSBCraig
Re: Jet Boat needs help
Ask on the jet drive forum at scream and fly.com those guys are really into what your needing, also check the buy/sell forum there you may be able to get a used one cheap.
I have a 97 sugar sand 120hp jet boat never had a problem never used oil. always maintained. was out driving and all of sudden it shut off. I tried to start it and it seems like the battery is dead. took it into the shop and was told it had a blown rod.. I didnt hear or see anything out of the ordinary. Shop already had the quote for me for a new engine. even made the comment that it was the best shape he has ever seen a 11 year old boat.. We dont know if were getting taken for a ride. Marina suggested we put a new engine in it .. IF we do should i buy a used engine.
HELP . We have no idea what to believe.
thank you
oops!
thank you
hi lady jet boat driver.....welcome to i boats :) and thanks for using the search function.....
may i suggest to post this question in the i.o forum....
on this site we have some of the best engine diagnosticians on the planet.
they .....well......they are just really really good.
if you post your question there. they will tell you what you can check your self to see if the marina is lying to you.
but just as a suggestion....drain the iol yourself....and look for peices of metal....if there is big chuncks in the oil......its toast
cheers
oops
thank you
Ayuh,....
I would think that this is a glorified Jet-Ski type of Jetboat,...
Probably powered by a converted Outboard 2 stroke motor....
If that's the case,...
Your Best bet for answers will be posting in the JetSki forum...
And,..
I would think the Marina is probably Right.....
Can you better identify the actual Motor,..???.. We really don't care What the boat is....
