j70tleda stuck trying to drop the lower unit
TBTech24
i have eveything ready to drop the lower unit but cant get the pin to come out of the shift rod connector. can anyone help.
boobie
Re: j70tleda stuck trying to drop the lower unit
Go to shop.evinrude.com and look up your mtr and go to cyl and crank case section. Look for pin # 87 and pull that. Then push the shift arm to port which will disconnect the shift rod.
TBTech24
thanks man. i knew i was messing up a step in the procedure. she dropped like a sack of potatoes.
