Scottish or anyone- Looking for suggestions. I have an air leak right on the inside of the seam where the tube is connected to the floor on the inside of the boat. Tricky spot. I'm leaning towards a llight sanding,cleanup with alcohal and a light bead of Marine Goop but not sure. Let me know...
I fixed my own recent water leak and tested boat yesterday, all is good.
First off, have you figured out how your air leak in that location came about? Based on your description it sounds like it could have been caused by your flooring, perhaps when you put it in place? I'd check every inch of the floor edge to make sure as you don't want it buggering any repair you make.
For air leaks, I would try the following. Buy some of these transparent, self adhesive bicycle patches. This is the brand I use on the boat and they work well, I never leave shore without them.
http://www.amazon.com/Park-Tool-Pre...464675818&sr=1-2&keywords=Self-Adhesive+Patch
Clean area, sand a little if you like, press on patch and apply weight evenly, leave for an hour or so. I use a Beanie Baby for this part as it's tiny beaded innards spread the weight out nicely.
The above should deal with most small air leaks. You can even apply a tiny spot of goop directly on the hole before applying the patch.
I'm confident this should work. If not, get back to me and we'll discuss grander solutions.
Good luck.
I still have the spring but not the ball bearing. Next week I will look into finding a bearing that fits, place it over the spring and trial various methods to hold said bearing in place, like a thing strip of duct tape. Will let you know how I get on.
You tried the Weedless wedge yet? Notice more thrust?
Hey Scottish-
"What I ended up doing was apply several layers of Goop, after surface prep of sanding and alcohol wipes, I haven't inflated it yet but the real test will be to use the boat and put the area through the stress of being loaded etc. I'm cautiously optimistic but we'll see."
If I have your description right, I'd try this.
Cut a patch of vinyl from one of the inflatable seats they give with the boat. Say two inches wide and four inches long.
Next step you can do one of two ways. Fold the patch evenly length ways, then place in a container of hot water folded, and place a weight on it to keep it folded. After a while take it out and keeping it folded, run it under the cold water tap (fawcett) so that the material hardens and keeps its folded shape. Or two, you can use an iron to press it while folded then run under cold water.
This 'seamed' patch will now slide neatly in to between the inflatable section and the floor. The idea being it will be glued on either side the boat seam. And you can make this patch twelve or even thirty inches long if you want to beef up the overall strength of the seam.
Before applying the pre folded patch, fill the puncture with your goop and let it dry. Then apply patch dead center over puncture area and use super glue to do it, pressing either side of the folded patch to the side wall and the floor.
However!
As I have said before on the forum, I've used super glue to no ill effects, it's my go to adhesive. However there's no guarantee all 'supers' are the same. So take a small patch of the boat vinyl - cut from the inflatable seat - and test your super glue of choice on it first, before putting it on your boat. This is the method I used to seal my recent water leak on the floor seam. I've used it on air leaks on my first boat too and it worked fine.
"I used the new Weedless Wedge and found it has less than stellar performance. The motor has a higher vibration, probably due to poor balance. Also, the speed/power is way down. I'm not dealing with any weeds where I fish this year. Wind is the main obstacle so I put the original prop back on and will carry the Wedge as a backup."
Surprised to hear this as I had the opposite result. You're positive it's the right wedge for your engine model?
Thanks for the offer of a spare engine inner you received, however I suspect if pushed I will just buy a new engine, already looking at a 55lb thurst Endura Max.
Why would I buy ANOTHER Kota after recent events? Well I am yet to identify another brand that has incremental throttle control which I would really miss. My friend has the standard 5 speed notch of regular motors and it drives him nuts, as like me his preferred trolling speed is between the notches.
Tell me if your fix works.
Hey Scottish-
However!
Thanks, interesting idea.
Fyi, I've people add the variable speed option with a PWM switch. "You can also use this. It Is a PWM, pulse width modulation, the same as the old maximizer. hook your battery to the input and the motor to the output. Leave speed setting on the motor on High and use the PWM knob to change speed. you will have infinite speed control from 0 to 100%"
Cool, I did not know that. The ones I just saw on Ebay look exposed to the elements, as in not encased in a waterproof case. How do you set this up against rain and lake water etc.?
Hey guys, I decided to make a trailer for my sea eagle foldcat, however, this could be very easily rearranged and modified to work on a mariner. It's the harbor freight mini trailer, I used 2x2 square tubing to extend the tounge, and 1x6 for bunks. Extended the wiring and you're done! All in around $225
Where did you get the tube steel? I'm looking into extending my tongue so I don't have to back my car into the water.
Hers my trailer setup
https://youtu.be/Qf3nLkkSUwk
I tried 1/4..... Don't do it..... I'm a big guy, but wouldn't do less than 15/32
Scottish- I don't know how it's waterproofed. I had read about them a while back and your post made me think of them. Searching the web I see it's pretty popular to do and I'm sure many of those folks are fishing in the rain so there must be a particular brand or a mod to make it work...
Any reason you just didn't weld the extension on it? I was thinking of asking them to just weld it..
