In Need of Alpha 1 U-Joint and Boot Advice
skyler4321
Just got a 03 Alpha 1 4.3L. It was not run this year. Found a broken shift cable boot and very small amount of water in the gear lube. Pulled the drive and found water in the u-joint boot. There is rust on the yokes from soaking in an inch of water. Looks like the gimbal bearing is junk. The u-joints are GKN perma-lube and feel good.
When I push the drive up, I don not see any cracks or other signs of degradation to the U-joint bellows. The failed shift cable bellows is full of small cracks when stretched.
Should I replace the u-joints and the u-joint bellows?
Thanks for the help.
Don S
Re: In Need of Alpha 1 U-Joint and Boot Advice
As a rule of thumb, the ujoint bellows should be replaced after 5 years. You're over that. The only other place for water to get into the bellows is from the large quad ring in the bellhousing between the drive and the bellhousing. If it gets reused, cut or damage when the drive is installed, water will get into the bellows. If it looks good, then you can bet money there is a hole in the bellows that you can't see.
HT32BSX115
Howdy,
If the shift cable boot is rotten and you can not identify when the all bellows were replaced, you probably should do a complete transom service.
If there's corrosion inside, U-joints, etc, you should probably replace them. Since there was water in there, I would probably do the gimbal bearing too....
Don't put it back together without checking/adjusting the alignment...
Regards,
Rick
skyler4321
I am about to buy tools for this job.
Do I need the bellows expander tools for the exhaust and u-joint bellows?
Thanks
hoot
Skyler, in my experience, if you don't replace the u-joints now, you will be replacing them next year. They feel fine when moving them by hand, but they will get rough. Your next post will be titled 'vibration when turning left and right, u-joints?'
skyler4321
Thanks
I would rather replace it all now.
Thinking if going with www.amarket.com parts.
They have the yoke and joints in a kit for the same cost as just 1 joint!!!
The same goes for the bellows.
Is this a case of you get what you pay for?
Fishermark
Thanks
I've ordered from amarket several times - I've had good experience with them - both on their prices and service.
You can ask what brand the bellows are. Then report back with what you find to get opinions on the brand. Most like the OEM, but several have commented that the Sierra works well.
ckaiser
I bought my bellows and tools from AMarket. They were fine. DO buy the bellows tool. Well worth it, IMO.
Also, when you pull the shift shaft to use the bellows tool, make sure you don't put it in reversed 180?. :) Fortunately, I found this before I took it to the lake...
Personally, I'd replace the joints and bellows while I had the drive out. Pretty simple while it's apart. I'd also replace the impeller if it hasn't been done in the last year. I did find that the sierra impeller kit didn't have the key or another part that slips my mind right now and I ended up with the mercruiser kit instead.
Take a good look at the water hose and oil hose (if it has one). Great time to replace those as well...
skyler4321
I am about to do the engine alignment. The engine was replaced in 2005.
I was looking at the rear mount with a fiber scope and the port side is almost touching the fiber washer and there is a lot of space on the other side. The front port mount is adjusted 5/8? lower than the other front mount. It looks like the front mounts are trying to roll the whole engine to the port side.
Should both rear mounts have about equal space over the fiber washers?
Thanks for your help
cr2k
Yes the rear (if properly replaced last time) have a "stack" that needs to be in the right order. Both should sit even and the front mounts compensate for any variance in the stringers.
But I guess if you get the alignment tool to slide in and out easy you are good to go.
skyler4321
Do I need to find a way to lift the front of the engine or can I bend the tab a little, use a wrench and then stake it back?
makinc80
as for the joints, they should be 7260 series. try a local driveshaft shop. i had mine replaced at driveline service of nj inc. on rt. 46 in clifton nj. took them the yokes and the installed the joints on the spot for a fraction of the joints you see from mercruiser. they used neapco high performance joints and put a small button zerk fitting in the cross instead of a plug so i can grease them next season. if your by nj call them 973-433-7900 it saved me time and money!
makinc80
also i made a bellows tool for approx $6.00. i bought a piece of 2" flat steel and some solid square stock at home depot. just modeled it after the ones on ebay. worked like a charm and all it took was a little welding and a little time!
Don S
For one thing, to check the alignment, you need an alignment bar, looking at the mounts with that scope will only tell you something is wrong, not if it's out of alignment or not.
Yes, there should be equal weight on the rear mounts, and the front mounts.
If the threads on the front mounts are clean, and educated elbow will tell you if you have equal weight on the front mounts, plus checking the alignment as you go till you get it perfect. Then when you tighten down the front mounts and recheck your alignment and it's off. They were not equal.
DO NOT go by how many threads are showing. You are assuming the hole was cut perfectly square to the stringers (not going to happen) and that the stringers are exactly the same height. (also not going to happen).
The alignment bar tells all.
Here is a thread (with video's) that covers about all of the alignment procedures.
http://forums.iboats.com/showthread.php?t=443992
skyler4321
I got the alignment tool today. Before starting I was able to get the tool in but it was tight. I evened up the mounts and in an hour and a half it was perfect. Last I rotated the engine.
270 has some drag , 90 is snug, 180 is tight and 0 stayed perfect.
What now?
Thanks for all the help.
telstar1
Try tweaking it a bit more, youre tight at 180 deg and perfect at 0.Obviously your coupler is a bit wobbly, try and get 180 and 0 the same,will give you best results imo.
skyler4321
Should I pull the gimbal bearing and use the alignment tool to tweak the coupler?
telstar1
There is no such thing as tweaking a coupler as far as I know.What youve got is what youve got. I believe every one of them is out of line a bit, it is how much that matters and I dont have that spec.Maybe someone else has the spec, Id love to know myself.If you can get it so you can pull it out without a "tug" in all four quadrants Id say you are good to go. A piece of precision 1 inch bar stuffed into the splines will also give you a visual guide as to how much it wobbles in the 4 positions.(the 1 inch bar is virtually the same size as inside of splines.) Look to see how close it is to gimbal brg or alternatively apply finger pressure to the bar sideways and up and down till it contacts gimbal brg. The more pressure it takes, the further out of whack it is in that axis. ie more wobble
Like i said, try and get it so alignment bar doesnt stick in any quadrant Hope this helps.
skyler4321
This coupler has probably been run misaligned and with a loose front mount since the engine was changed in 2005. It did not sound happy over 1500 RPM when I ran it.
Do they get a wobble from running out of alignment or does it just happen?
Will I save myself a lot of grief if I just change it now?
