Re: In Need of Alpha 1 U-Joint and Boot Advice
First ,when I said "tweak" in my first response I meant continue fine tuning alignment, just in case that confused the issue.As to whether you should change coupler now, that kind of depends on your inclination and budget.
On one hand, you could align best possible and try boat out. Make sure you have other vibration sources such as prop under control so that if there is vibration you know where its likely not coming from.(this could be accomplished in a few hours),
on other hand you could remove engine, check whats going on with those rear mounts while its out,check coupler up close,buy a new one if it seems worse than a new one(theyre not always true either,be sure and check it before install),and put it all back together.This is a couple of days work for your avg backyard mechanic. Method a would be fastest but may result in method b ,(or not))
mho
mho
