Re: In gear when started
Sometimes when the engine is tilted, it flexes the cables and the engine will go into gear.
However, you did not say what engine you have--it makes a difference in how to adjust the linkage. There are other concernsthough.
For example, when the linkage is adjusted with a bias toward forward, it will go into forward gear while the handle is in neutral. Also, as the system gets old some slop is induced. So if you pull the handle from forward to neutral, it will stay engaged in forward while the handle is straight up in neutral position. Try moving the handle from forward to reverse and then into neutral. Sometimes it may take once or twice to do it and you need to get the feel of it.
