impeller anybody
khoehi
Can anyone help me with replacing an impeller on a 1999 force 120. i have removed all of the lower unit bolts, but i cant figure out what to take off at the powerhead to get the l/u to drop. thanks
roscoe
Re: impeller anybody
Welcome to iboats.
There should be nothing to take off at the powerhead.
Remove the trim tab above the prop.
Remove the bolt that is hidden up in the trim tab pocket.
Then remove the 4 bolts on the sides of the lower unit.
The shift rod is splined, and should slide apart as the lower unit is dropped down.
