Sea Rider
- Sep 20, 2008
- 12,345
With OB constantly use, will see white lines forming on cylinder head gasket and water droplets leaking in middle gasket metal ring. OB will miss/hesitate when on cold starts. Warming OB more won?t cure the symptom, will just remedy it shortly to miss again when cold. This head breaking symptom is not mentioned on any Service Manual nor is detectable during a compression test. It?s common sense and knowing internally how all related parts works together as a unit.
Second bad news is that small water droplets leaking from gasket water labyrinth will end rusting, seizing head bolts to crankcase which will become hard to remove and even breaking them against internal threads. Crankcase will need to be sent to the solder guru to have broken bolts carefully removed from crankcase.
Crankcase and cylinder head mating surfaces were filed to smooth cond to seal spot on along new head gasket torqued to factory specs. All internal water passages were soaked with vinegar or W40 for a while, then scrapped off with a sushi wooden stick to remove most traces of salt & oxidation inside.
All water orifices were sprayed with pure vinegar, W40 or carb cleaner depending on the condition found and poked with wooden sushi cotton swaps of different calibers to match different orifice diameters.
Although thermo was serviced before at first 300 worked hours from new, was found bit salty and rusty (1) was soaked in pure vinegar for one hour and a half, dried and polished with an old toothbrush and regular toothpaste, looks mint and works as brand new (2).
Carb & Fuel Lines.-
Although carb was working fine, was disassembled in pieces, upper and lower bodies soaked in hot water for 15 minutes and flushed afterwords with an overdose of generic carb spray. After assembly a carb/timing advance sync was mandatory to make. Running carb bowl dry after use, is a big plus keeping carb interior immaculate clean.
Fuel pump, was not disassembled as internal diaphragm won?t fit or sit nicely again on its original resting position due to E8 deformation. Tank to carb fuel lines were purged with fresh fuel.
Final Assembly.-
Installed new base gasket, greased drive shaft upper splines, sat powerhead and torqued lower bolts tight to pan.
Electrical Components.-
Electrical connectors, bullet connectors and all component grounds have been cleaned and polished to a shinny condition.
All small, medium and large bolts have been removed, threads cleaned and assembled lightly greased with OMC Triple Guard, when in need to remove them again, will be breeze to do so.
Before starting OB on muffs and prior sitting thermo on housing, made a 15 minute high pressure water flush direct on thermo orifice and a 15 minute one on discovered exhaust cover flushing port, the amount of water that flows unrestricted through water labyrinth, peeing port and idle relief port made my day.
In 600 worked hours this 18 has consumed 6 spark plug sets, 7 gear oil refills, 1 cylinder head gasket, 1 thermo gasket, 1 base gasket, 1 can of engine tuner/ power guard, 1 carb spray. Carb, fuel pump, lower leg parts, all electrical components are still original. Ain?t that sweet low cost.
Conclusions.-
No matter how long you flush an OB ON while boating on salted waters will alyways accumulate salt layers due to countless heat/cold cycles through continuous use. Deep removal is only possible by rubbing, scrubbing mechanically. Will Salt Away work that deep, who knows, will need to disassemble cylinder head to check, seeing is believing..
Although Engine Tuner, Power Guard sprays didn?t clean combustion and exhaust chambers to perfection as one would imagine while spraying product though carb with OB warmed up, do find that OB regains its lost agility when applied every 50-100 worked hours, a highly recommended product to have it handy.
Products used for restoration : OMC Triple Guard Grease, Automatic Transmisiom Gear Oil, W40, Engine Tuner, Acrylic Thinner.
For a perfect OB restoration It?s not the two weeks spent what counts, for me it?s all about the personal satisfaction of doing an excellent priceless job to maintain my beloved 18 alive while having extreme fun doing it for peanuts cost.-
Happy Boating...
Note : Post starts page 8..
